Threads: 5
i created some scenes in mosaic to trigger various objects and they were working fine but now all the scenes no longer work ever since I created a scene that triggers around 50 objects in various floors. i can't edit, remove or move any of them
Threads: 28
Press F12 and check for any errors in the console.
What is the CPU load?
Threads: 28
Send me your backup to PM, use we transfer.com or similar
Threads: 28
It works fine for me, maybe you are using not the latest version? Try using different browser.
How did you manage to add more objects to sceene than amount of objects in a room?
For such big scenes it is better to use LM scenes as then object sending is better managed. You may overload a bus with such massive Mosaic scenes.
Threads: 28
Mosaic scenes are design to control object from the room it is created, not possible to move it. They are for end user to create himself some simple scenes/schedulers. Use LM scenes in LM tab Scene for complete freedom.
