01.07.2015, 11:37
In case a full control Streaming Player functionality is needed from LogicMachine, you can use HTTP commands.
E.g. commands like Update DB, Edit Playlists can be implemented in such a way.
Please see more detailed description and example on HTTP command implementation here:
http://openrb.com/docs/amati.htm
Please note that in case regular commands, like Play, Pause, Next, Previous, Play specific track/playlist/radio, are necessary to execute from LogicMachine or/and KNX, you can use built in Streaming Player to KNX mapper located in System config --> Network --> KNX Audio Control
