Amati.linea HTTP requests
In case a full control Streaming Player functionality is needed from LogicMachine, you can use HTTP commands.
E.g. commands like Update DB, Edit Playlists can be implemented in such a way.
Please see more detailed description and example on HTTP command implementation here:
http://openrb.com/docs/amati.htm
Please note that in case regular commands, like Play, Pause, Next, Previous, Play specific track/playlist/radio, are necessary to execute from LogicMachine or/and KNX, you can use built in Streaming Player to KNX mapper located in System config --> Network --> KNX Audio Control
[Image: map_radio_knx.png]
(01.07.2015, 11:37)edgars Wrote: In case a full control Streaming Player functionality is needed from LogicMachine, you can use HTTP commands.
I noticed that for CMD=ZONE, Param 1 to 4 are inverted. For example cmd=zone,param=1 enables Zone 4 instead of zone 1.
(03.07.2015, 08:06)bvanden Wrote: I noticed that for CMD=ZONE, Param 1 to 4 are inverted. For example cmd=zone,param=1 enables Zone 4 instead of zone 1.
You are right, we will fix this in next firmware release
Hi all! please help me.
if not used "Amati.linea", I used a music store, example is :NAS Synology ds412.
how to LM3 can access the NAS to play music? (play music via "trivum" , it has an Internet connection and a ip address )
Thank all!
Hi all, i am using KNX Audio Control for radio stream website, i am facing a problem in Network configuration, If some one have any idea about Network configuration so please share with me. i am using this on http://www.africaradios.com/ and http://www.listenfmradios.com/
can you please describe more on what is the issue on your Streaming Player, is it not streaming the internet radios? By the fault, the IP settings are set to DHCP-client so no additional settings are needed from your side. If you do manual IP settings, please make sure to specify IP, subnet, gateway and DNS server.
What is the command for Amati.linea HTTP requests to reboot the player ? On AIRPLAY the zones disapear regurlarly - only way to fix is to reboot the player. So I need to write a script but cannot remember the command for rebooting. Thx.
URL for reboot: http://192.168.1.1/cgi-bin/audio/request...est=reboot
But the actual problem is not in the streaming player. During our tests we found that discovery messages are not always received by iOS devices but are always sent by the streaming player. This might also be a wireless/router issue.
