Threads: 22
Last night I was playing around with some scripts, then out of nowhere my script disappeared, I wrote it again, but same thing happened.
The error log shows this:
![[Image: nSi8oC1.png]](https://i.imgur.com/nSi8oC1.png) I thought it could be a glitch or maybe a storage problem, I disabled the script, and went to sleep.
Now I discovered that it happened with another script..
What do I do?
The LM is only 1 month old!
(The script does not disappear from the list, but all the text within the script editor disappears.)
Threads: 63
(14.10.2023, 09:54)Novodk Wrote: Last night I was playing around with some scripts, then out of nowhere my script disappeared, I wrote it again, but same thing happened.
What do I do?
Are you using FB editor to generate the script?
Best regards Cristian
Threads: 22
(14.10.2023, 11:05)CristianAgata Wrote: (14.10.2023, 09:54)Novodk Wrote: Last night I was playing around with some scripts, then out of nowhere my script disappeared, I wrote it again, but same thing happened.
What do I do?
No, I am not.
Threads: 20
Sometimes a reboot solve the problem
Threads: 43
Threads: 22
(15.10.2023, 18:01)Dré Wrote: Sometimes a reboot solve the problem
Tried that, did not help.
Threads: 63
A client of mine has the same problem. So I ask you some information:
1st firmware installed
2nd you lost all or only one script
3rd have you made some changes to order tab as object, mosaic, password admin?
4th after a sync of the project, have you lost again he script?
Sorry for all those questions but we are trying to understand what is the condition when this happens.
I have other logic in test but at the moment I can't reply the problem.
Threads: 22
(16.10.2023, 16:46)CristianAgata Wrote: Hi,
Hi Cristian
Firmware version:20230612
I lost 2 scripts (id 23 and 24), but only the script, the database entry id is still there:/scada-main/main/editor?id=24
But if I go into script id 23 and write a new script it disappears again.
Threads: 63
(16.10.2023, 17:59)Novodk Wrote: (16.10.2023, 16:46)CristianAgata Wrote: Hi,
Hi Cristian
Thanks I will ask to my technician, if it seems our case.
Threads: 95
Last weekend i had the same problem, version: 20230420 (with patch)
Threads: 43
Do you know the exact steps to reproduce this issue or does it happen randomly?
Threads: 95
I don't know exactly the actions. I was creating and testing a script and then I saw this message in the error log. Unfortunately I cannot provide more information.
