Threads: 12
I have a LSS100200 working (can connect to it and add scripts or objects), but each time I change the IP address and apply changes, the device reboots but same old IP address is keep coming!
I also noticed that any new script or object is not saved after turning the device off.
Thanks!
Threads: 8
25.10.2023, 18:01
(This post was last modified: 25.10.2023, 18:01 by Erwin van der Zwart.)
Sounds like your SD card has become read only and needs to be replaced..
I would make an image of the current SD card with USB Image Tool and write that image back to a new SD card (preferably a Industrial quality), and insert the new card and boot it.
Up to 32GB will work but it's better to use a smaller card of better quality (Industrial, as Erwin suggested).
