groups mass edit
is there a way to edit groups not one by one? like mass edit in object tab.
for example - I imported KNX project and need to set E flag to all objects. how can I do that&
(06.11.2023, 12:30)AEK Wrote: is there a way to edit groups not one by one? like mass edit in object tab.
found temporary solution
db:query('UPDATE canx_groups SET export = 1')
No other solution at the moment. After making db changes you need to reload CANx daemon:
require('applibs.canxcore').reload()
(06.11.2023, 15:05)admin Wrote: No other solution at the moment. After making db changes you need to reload CANx daemon:
I've reboot LM complitly
