Admin credentials
I have a question related to LM5 admin credentials (ID/password).
Is there a way to set new admin credentials if the old ones are lost? Can I get the admin credentials from some database etc? Or can I reset the admin credentials somehow?
I have tried to use admin & admin on login already.
Thanks for your time,
Tanislan
EDIT: Changed the earlier post a bit for the privacy.
Check PM
Instead of starting a new, Lost password on a spacelynk (but guessing it's the same principal as LM5) Is there away without reseting it?
Can you find it on the memorycard?
Password is hashed, you can't read it.
So only factory reset and wiping all data is possible?
Is it then possible to save the config somehow? bacnet server with multiple devices reading from it
