Threads: 11
I believe it would be very useful in the ETS project (.knxproj) import procedure to have an option that allows you to update the description for existing objects already imported into LM5 previously.
This allows you to keep information aligned without requiring manual changes.
Threads: 1
Same here too. Mass delete and import back isn't an option.
Also, during the mass delete and import action, if there is any KNX telegram receive by LM, the address will be create without any description.
Simplest and best solution is to have an option to "overrride" names during project import.
Threads: 43
To prevent new groups from appearing you can disable "Discover new objects" in Utilities > General configuration.
An option to update existing objects during KNX project import will be added soon.
