Modbus Profil/Bool values?
Hey guys,
I try to read the values from my Sungrow Inverter. When i try to read values with the "Read Check" I get good values. After that I made the profil for the device, added it and it seems that i only get boolean values but i don't know what to change.
My Profil:
{   "manufacturer": "Sungrow",   "description": "SH10RT Inverter",   "mapping": [     {       "name": "NominalOutputPower",       "bus_datatype": 1,       "datatype": "uint16",       "type": "inputregister",       "address": 5000,       "units": "kW",       "value_multiplier":0.1     },     {       "name": "Daily Output Energy (PV+BAT)",       "bus_datatype": 1,       "datatype": "uint16",       "type": "inputregister",       "address": 5002,       "units": "kWh",       "value_multiplier":0.1     },     {       "name": "Total Output Energy (PV+BAT)",       "bus_datatype": 1,       "datatype": "uint32",       "type": "inputregister",       "address": 5003,       "units": "kWh",       "value_multiplier":0.1     },     {       "name": "Inside Temperature",       "bus_datatype": 1,       "datatype": "uint16",       "type": "inputregister",       "address": 5007,       "units": "°C"     },     {       "name": "MPPT 1 Voltage",       "bus_datatype": 1,       "datatype": "uint16",       "type": "inputregister",       "address": 5010,       "units": "V",       "value_multiplier":0.1     },     {       "name": "MPPT 1 Current",       "bus_datatype": 1,       "datatype": "uint16",       "type": "inputregister",       "address": 5011,       "units": "A",       "value_multiplier":0.1     }       ] }
[Image: Q5Q1P]
Can somebody help me please. And yes I am very new to this whole topic
You did set "bus_datatype": 1, this is a boolean change to "float16"
You mean "bus_datatype": float16
"bus_datatype": "float16",
(02.01.2024, 16:29)Daniel Wrote: "bus_datatype": "float16",
Thank you. Worked out fine after updating the firmware of the modbus device.
