Hey together,
i finally made it and can read values from my modbus devices (thank you Daniel). I thought that if i connect both devices with one object that the value will be written to the other modbus device. In particular i am talking about a PV inverter and a heat pump. I want to send the values of the current DC production and und current DC Export to the heat pump. But somehow it does not work. Unfortunately i didn't find any information in the forum.
The steps: i read the values of the inverter and write it to an object 12/1/1 and 12/1/2 (write on bus enabled)
I added the heatpump and connected the datafields to 12/1/1 and 12/1/2
Below i send you the Profil for the heatpump.
is the procedure wrong i should have done it with a script? (German manual)
Can somebody help me out with this? i have seen several threads about connection the idm heatpump with iobroker but i didn't see a difference to my parameters.
thx in advance
"manufacturer": "IDM",
"description": "Heat Pump",
"mapping": [
"name": "Aussentemperatur",
"bus_datatype": "float32",
"datatype": "float32",
"type": "inputregister",
"address": 1000,
"units": "°C",
"value_multiplier":1,
"writable": true,
"read_swap": "n"
"name": "Aktueller PV Überschuss",
"type": "register",
"address": 74,
"units": "kW",
"writable": 1,
"read_swap": "n"
"name": "Aktuelle PV Produktion",
"type": "register",
"address": 78,
"units": "kW",
"writable": 1,
"read_swap": "n"
"name": "Aktuelle Leistungsaufnahme",
"address": 4122,
"units": "kW",
"read_swap": "n"
}Can somebody help me out with this? i have seen several threads about connection the idm heatpump with iobroker but i didn't see a difference to my parameters.
thx in advance
