Threads: 0
HI
I would like to install LM on an Android that doesn't connect to the play store, is it possible to have the apk? Thank you
Antonio
Threads: 26
Which android version?
Threads: 26
Threads: 26
As you posted it under LM Home app then maybe try using it instead of the old LogicMachine app
https://kb.logicmachine.net/notification...fications/
PS. When sending notifications you can log the errors ans see what it says.
Threads: 26
LM Home meant to be the simpler one
You just need to create yourself a user (never use admin account as it will not be remembered) and in this user account add your cloud email. Set permissions and sync LM Cloud app.
Later just open LM Home app and when on local netowrk with LM it will connect to the local LM. When not on local network it will go to cloud. You can force cloud connection by long press on LM home app icon, there are more options there.
The idea behind is simply to not need to select, it will do it automatically.
PS. The credentials are saved in phone cache and the saving procedure is managed by your mobile. Sometimes you must let the app open for a minute or two for the system to save credentials. If you kill the app straight on credentials might not be saved.
Threads: 26
You don't need the Push notification app at all. It was only needed in combination with LogicMachine app.
For the LM Home app the LM cloud app does everything. Just use this example to send notifications.
Threads: 26
This means all was sent correctly
Threads: 26
They are sent only not received. Did you allow permissions for LM Home app to receive notifications?
Threads: 26
If you using Push notifications app then you are not using LM Home app. The script above is for LM home app not LogicMachine app which is the older version.
