W4K: Gree HVAC controlled with KNX
Hi all,
I have a Gree HVAC and want to controll it with KNX - ideally with my w4k. Has someone already tried to implement this?
A documentation is available on github: https://github.com/tomikaa87/gree-remote
The easiest solution is to get something like an RPi and use MQTT integration. For testing you can run a VM on your computer.
Thank's for the idea with the VM for testing.
Any chance to get a MQTT broker running on the W4K? Controlling the HVAC is my only use case for the MQTT broker. In this case a RPI seems already a bit overengineered.
Only LM has an option to run MQTT broker. But you still need some other device to run the MQTT bridge: https://github.com/arthurkrupa/gree-hvac-mqtt-bridge
