dark / light mode
Hello, Is it possible to put a switch on the visualisation to switch between dark theme and light theme ?
Do you want to change it locally (only for the current user session) or globally (for all users)?
(08.03.2024, 07:43)admin Wrote: Do you want to change it locally (only for the current user session) or globally (for all users)?
I want only for the current user but if it's not possible global is good
Add this to Custom JavaScript:
$(function(){
  if (window.Storage) {
    var dark = !!Storage.get('darkmode', '');
    $('body').toggleClass('dark', dark);
    $('.toggle-dark-mode').off('vclick').on('vclick', function() {
      dark = !dark;
      Storage.set('darkmode', dark ? 'y' : '');
Create a dummy object and attach a visualization element to it. Set Additional classes to toggle-dark-mode
Clicking this element will toggle between light/dark mode. This setting is stored in browser's local storage.
(08.03.2024, 09:18)admin Wrote: Add this to Custom JavaScript:
$(function(){
      dark = !dark;
$(function(){
      dark = !dark;
when I switch from one mode to another the page trends do not immediately change color. I have to refresh the page manually
This should work with iframes:
$(function(){
  if (!window.Storage) {
    return;
  var bc = new BroadcastChannel('darkmode');
  function get() {
    return !!Storage.get('darkmode', '');
  function set() {
    $('body').toggleClass('dark', get());
    Storage.set('darkmode', get() ? '' : 'y');
    bc.postMessage('set');
    set();
  bc.addEventListener('message', set);
  set();
