javascript daily URL change
I have a widget that loads multiple iFrames showing weather info and one of them has the format https://<base_url>/#dYYYY-MM-DD
I can use the dynamic url examples from the forum to use a virtual group to trigger the changing url, but calculation of the string is simple in javascript and I would prefer to have things done in one place.
How do do I apply the src change every time this widget/iFrame is loaded without using a virtual group?
This works:
$(function(){   if (typeof grp != 'undefined') {     grp.listen('0/250/247', function(object) {       let d = new Date();       let forecastDate = d.getFullYear() + '-' + ('0' + (d.getMonth() + 1)).slice(-2) + '-' + ('0' + d.getDate()).slice(-2);       $('.hourlyforecastbak').find('iframe').attr('src','https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate);     }, true);   } });
Attempt that does not work:
$(function(){   $('iframe').load(function() {     let d = new Date();     let forecastDate = d.getFullYear() + '-' + ('0' + (d.getMonth() + 1)).slice(-2) + '-' + ('0' + d.getDate()).slice(-2);     $('.hourlyforecast').find('iframe').attr('src','https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate);   }, true); });
Try this:
$(function() {   $('iframe').one('load', function() {     let forecastDate = (new Date()).toISOString().split('T')[0];     this.src = 'https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate;   }); });
Thanks, that works but I don't understand why it did not change every iFrame?
The code below is working.
I kept the search for .hourlyforecast but perhaps there is a more elegant way of specifying the wanted class or Custom name in the load event.
The forecastDate string is to get the local time instead of UTC.
$(function() {   $('iframe').one('load', function() {     let d = new Date();     let forecastDate = d.getFullYear() + '-' + ('0' + (d.getMonth() + 1)).slice(-2) + '-' + ('0' + d.getDate()).slice(-2);     $('.hourlyforecast').find('iframe').attr('src','https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate);   }); });
Unfortunately this did not update overnight with the changed date. Do I need to go back to using a virtual group that changes regularly as a trigger to update the url?
You can periodically check if the date has changed and modify the iframe src accordingly. Use setInterval: https://developer.mozilla.org/en-US/docs...etInterval
OK. Thanks again.
