19.04.2024, 09:47
The Switch button automatically turn on without feedback address.
problem in mosaic
19.04.2024, 09:47
19.04.2024, 09:55
If you linked the status object and the status is not send then this is the expected behaviour. If you do not have feedback then just use control object.
19.04.2024, 10:30
I am using a status object, this problem only happen when there is a power outage.
19.04.2024, 10:38
This is how it meant to work, If you use status then object will be showing what is status value not control. You can set: Read during start-up: for the status object or read periodically. See object settings.
Ctrl+F5 |
« Next Oldest | Next Newest »
