Threads: 164
Greetings
I changed the SIM and mounted a tested working one on a phone, my problem is that it does not receive IP from the cellular network, even if the signal is there.
Latest firmware version available
What can it be?
Thank you
Check that you have correct APN and dial number settings.
Post what you have in System config > Status > System log.
Threads: 164
(23.05.2024, 07:52)admin Wrote: Check that you have correct APN and dial number settings.
APN is correct
need the dial number of SIM ?
thank's
Default dial number is *99***1# but it might be different, check with your operator.
Also post what you have in System config > Status > System log.
Threads: 164
(23.05.2024, 07:58)admin Wrote: Default dial number is *99***1# but it might be different, check with your operator.
Also post what you have in System config > Status > System log. the dial number be set in 3G/4G/ ppp connection or in resident sms script?
in system log see
May 23 08:04:52 LM5R_VERGATO daemon.err pppd[1932]: Connect script failed
Dial number is set in System config > Network. But you don't need to specify it if the default one is used.
Is SMS script working for you?
Threads: 164
(23.05.2024, 08:11)admin Wrote: Dial number is set in System config > Network. But you don't need to specify it if the default one is used.
Yes I use only one number
the error il log why? error ppp connection, not have ip from mobile network.
If SMS script is working then the hardware is ok. This means that your configuration is wrong. Maybe a username or password is needed. Your operator should provide all settings - APN, user/password (if applicable) and dial-up number.
Threads: 164
(23.05.2024, 08:31)admin Wrote: If SMS script is working then the hardware is ok. This means that your configuration is wrong. Maybe a username or password is needed. Your operator should provide all settings - APN, user/password (if applicable) and dial-up number.
I use same SIM OPERATOR on other LM REACTOR and the same config working good , this no ?
Have you tried using this SIM on a different LM?
Threads: 164
(23.05.2024, 08:48)admin Wrote: Have you tried using this SIM on a different LM?
Now I have put new SIM tested on other LM and the new SIM working on ther LM.
Threads: 164
24.05.2024, 06:27
(This post was last modified: 24.05.2024, 07:27 by Frank68.)
(23.05.2024, 08:51)Frank68 Wrote: (23.05.2024, 08:48)admin Wrote: Have you tried using this SIM on a different LM?
now I have ip from network but have this problem in log
attempt to call global 'sendsms' (a nil value) stack traceback:
thank's
It's not a user script, it's an init sequence of the 3g/4g services. Usually this error means that the configuration is incorrect.
If you are sure that all settings are correct then the only option is to replace the SIM card.
Threads: 164
(24.05.2024, 07:31)admin Wrote: It's not a user script, it's an init sequence of the 3g/4g services. Usually this error means that the configuration is incorrect.
I check the sim on phone and work correctly
the IP is provided from mobile netwok but have this error.
Disable SMS script and 3g/4g connection then run this script once and post what you get in Logs. Don't forget to change apn variable value.
Code: apn = 'PUT_YOUR_APN_HERE'
dial = '*99***1#'
io.writefile('/sys/class/gpio/export', 8)
io.writefile('/sys/class/gpio/export', 71)
io.writefile('/sys/class/gpio/gpio8/direction', 'high')
os.sleep(1)
io.writefile('/sys/class/gpio/gpio8/direction', 'low')
io.writefile('/sys/class/gpio/gpio71/direction', 'high')
tty1 = '/dev/ttyACM3'
tty2 = '/dev/ttyUSB2'
for i = 1, 20 do
os.sleep(1)
if io.exists(tty1) then
tty = tty1
break
elseif io.exists(tty2) then
tty = tty2
break
if not tty then
log('init failed')
return
buf = {}
function send(cmd, timeout)
port:write(cmd .. '\r\n')
local res, err = port:read(1000, timeout or 1)
return res, err
function sendlog(cmd, timeout)
local res = send(cmd, timeout)
if res then
buf[ #buf + 1 ] = res
port = require('serial').open(tty)
log('open port', tty)
for i = 1, 20 do
res = send('AT')
if res then
break
if not res then
log('no response')
return
sendlog('AT&F', 10) -- reset settings
sendlog('ATE1') -- echo enabled
sendlog('AT+CGDCONT=1,"IP","' .. apn .. '"') -- set apn
sendlog('ATD' .. dial) -- connect
res = table.concat(buf)
log(res)
Threads: 164
(24.05.2024, 08:45)admin Wrote: Disable SMS script and 3g/4g connection then run this script once and post what you get in Logs. Don't forget to change apn variable value.
dial = '*99***1#'
os.sleep(1)
for i = 1, 20 do
os.sleep(1)
tty = tty1
break
tty = tty2
break
if not tty then
log('init failed')
return
buf = {}
return res, err
if res then
for i = 1, 20 do
res = send('AT')
if res then
break
if not res then
log('no response')
return
log(res)
this is the log file
* string: AT&F
OK
+CPIN: READY
SMS DONE
PB DONE
NO CARRIER
+PPPD: DISCONNECTED
ATE1
OK
AT+CGDCONT=1,"IP","internet.it"
OK
ATD*3332958126#
Keep the dial number default (dial = '*99***1#') and try again. This number is never your SIM number.
Threads: 164
(24.05.2024, 08:59)admin Wrote: Keep the dial number default (dial = '*99***1#') and try again. This number is never your SIM number.
the log
* string: AT&F
OK
+CPIN: READY
SMS DONE
PB DONE
NO CARRIER
+PPPD: DISCONNECTED
ATE1
OK
OK
ATD*99***1#
CONNECT 115200
Connect script fails because of "NO CARRIER" message meaning that there's no mobile connection.
Run this updated script and post what you get in Logs:
Code: io.writefile('/sys/class/gpio/export', 8)
os.sleep(1)
for i = 1, 20 do
os.sleep(1)
tty = tty1
break
tty = tty2
break
if not tty then
log('init failed')
return
buf = {}
port:flush()
return res, err
if res then
return res
for i = 1, 20 do
res = send('AT')
if res then
break
if not res then
log('no response')
return
function readstatus()
local data, res, simok, network
data = sendlog('AT+CSQ')
if data then
res = data:match('+CSQ: (%d+)')
res = tonumber(res)
if res then
log('Signal: ' .. tostring(res))
log('Signal: no response')
log('Signal: no data from port')
data = sendlog('AT+CPIN?') or ''
if data:find('CME ERROR') then
log('SIM: not found')
elseif data:find('+CPIN: READY') then
log('SIM: OK')
simok = true
log('SIM: unknown')
data = sendlog('AT+COPS?')
if data then
res = data:match('+COPS: %d+,%d+,"(.*)",%d+')
if res then
log('Network: ' .. tostring(res))
network = res
log('Network: no info')
log('Network: no data from port')
return simok and network
for i = 1, 20 do
if readstatus() then
break
log(res)
Threads: 164
24.05.2024, 09:35
(This post was last modified: 24.05.2024, 09:41 by Frank68.)
(24.05.2024, 09:27)admin Wrote: Connect script fails because of "NO CARRIER" message meaning that there's no mobile connection.
os.sleep(1)
for i = 1, 20 do
os.sleep(1)
tty = tty1
break
tty = tty2
break
if not tty then
log('init failed')
return
buf = {}
port:flush()
return res, err
if res then
return res
for i = 1, 20 do
res = send('AT')
if res then
break
if not res then
log('no response')
return
if data then
res = tonumber(res)
if res then
log('SIM: OK')
simok = true
log('SIM: unknown')
if data then
if res then
network = res
for i = 1, 20 do
break
log(res)
after restart
* string: AT&F
OK
+CPIN: READY
SMS DONE
PB DONE
NO CARRIER
+PPPD: DISCONNECTED
ATE1
OK
AT+CSQ
+CSQ: 99,99
OK
AT+CPIN?
+CPIN: READY
OK
AT+COPS?
+COPS: 0
OK
AT+CSQ
+CSQ: 99,99
OK
NO CARRIER
+PPPD: DISCONNECTED
AT+CPIN?
+CPIN: READY
OK
AT+COPS?
+COPS: 0
OK
AT+CSQ
+CSQ: 99,99
OK
AT+CPIN?
+CPIN: READY
OK
AT+COPS?
+COPS: 0
OK
AT+CSQ
+CSQ: 12,99
OK
AT+CPIN?
+CPIN: READY
OK
AT+COPS?
+COPS: 0,0,"WINDTRE",2
OK
