Threads: 58
Hi all,
are they special parameters to setup in order to use
homelynk.schneider-electric.com remote acces server ?
I have no problem to use it with a WiserForKnx, but impossible to login to a SpaceLynk in an other site !
Thank's in advance for your help,
Have a good day,
Dominique.
Threads: 35
As far I know SL is not using SE cloud but you should contact SE support as this is 100% SE stuff.
Threads: 58
Ok Daniel, I understand.
Thank's.
Threads: 8
Recently SL has got the option to use the new app, so it should be possible now to register the SL also to the cloud as far as i know...
Threads: 8
It’s not Wiser Home but Wiser KNX app, yes the old one is already removed and the new app is currently in preparation stage to be released, should be a few weeks from now.
Threads: 1
I have the new App "Wiser KNX"
3 different Wiser is registered in my App
Problem is if one of them is dissconnected. Its not possible to switch to the others when this happens
