Threads: 83
hello dears,
When changing the pop up widget value the background set point changed seem like when press on the widget it also press on the setpoint in the background!
I have a video describe the issue but I couldn't upload it here!
Best Regards,
Threads: 31
Upload it somewhere and drop a link
Threads: 31
send me your backup to PM
Threads: 31
We were able to reproduce it but for fix you must wait till next FW. There is no quick work around.
Threads: 83
Thank you,
I appreciate if there is a quick work around even like changing the widget position to not be above the setpoint!
its very noisy for the customer!
Best Regards,
Rework the widget so the custom value select does not overlap the circular slider. You can also try setting absolute coordinates for the widget.
Threads: 31
Widget position: in widget settings
