Creating a custom widget
Does anybody have a good reference/manual/white paper for learning how to create "custom widgets" ?
See attached, we can share the widgets src if needed but any custom widget will be only visible locally not in cloud.
.pdf   Widgets docs.pdf (Size: 801.3 KB / Downloads: 82)
Hello everyone,
sorry if this has already been answered, but I could not find definitive info.
I've read the attached document and I've got the following doubts:
- Will this add a new custom widget I can use in the admin UI of the old visualization (scada) when creating pages ?
- Where should I upload the files with the described structure ? Which ftp user should I use ?
Thanks in advance for your help
Antonio
This refers to Mosaic only. It is recomended to use new Visu for any new projects.
Thank you Daniel for your answer.
I didn't mention I'm actually using wiser for knx, and as such I think I'm not able to use the new Visu. Correct ?
This is correct.
Thanks, and is it possible to create a custom widget for the old visualization running on wiser ?
Only the normal way, but not via code.
