Remote service without basic auth
I am trying to use Remote services with an LM with 20240426 firmware but since there is no more basic auth, it does not work and always asks to login (if I use get request through browser). Is there a solution? Do I need to add some body to the request maybe?
Working example using Fetch API:
async function send() {
  var url = 'http://192.168.0.9/scada-remote?m=json&r=grp&fn=write&alias=0/0/1&value=1'
  var user = 'remote'
  var pass = 'Remote123'
  var headers = new Headers()
  headers.append('Authorization', 'Basic ' + btoa(`${user}:${pass}`))
  var res = await fetch(url, { method: 'GET', headers: headers })
  console.log(res)
Ok, that could be a problem since I am trying to exchange info with Yealink phones, which can not make requests with headers. Is there a way I can make API calls without a header?
You can create a .lp script instead: https://kb.logicmachine.net/misc/apps/#lp-scripts
It does not require authentication if placed in the public directory.
(29.07.2024, 06:25)admin Wrote: You can create a .lp script instead: https://kb.logicmachine.net/misc/apps/#lp-scripts
Interesting, could you give me an example of a script like this?
Check this: https://forum.logicmachine.net/showthrea...7#pid20407
The example above can be placed in user directory so only authorized users can access it.
