Threads: 14
30.07.2024, 09:05
(This post was last modified: 30.07.2024, 09:05 by Ceros2112.)
is it possible to put objects from a template on top of every other objects in the page that use the template? I tried wit z-index but it doesn't work.
Threads: 14
Ok, so if I have widgets on the pages and not on the layout basically I can't use it, right?
Thanks for your help
Threads: 45
Can you provide an image of what you want to achieve?
Threads: 45
If you link a menu item with a widget then the widget contents will be placed on top everything else because widgets are placed on a separate layer that has higher z-index than plan and layout.
Threads: 14
Yes, but the menu is on a layout and the widgets are on a page
