reactor modem check
hi
I have two reactor lm5p2-lte that with a storm stopped seeing the SIMs, in one the SIM had signs of burning, now when I try to use the script to verify the modem it tells me init script failed in both, the 2 modems could be damaged
for check the modem i use this script
apn = 'PUT_YOUR_APN_HERE'
dial = '*99***1#'
io.writefile('/sys/class/gpio/export', 8)
io.writefile('/sys/class/gpio/export', 71)
io.writefile('/sys/class/gpio/gpio8/direction', 'high')
os.sleep(1)
io.writefile('/sys/class/gpio/gpio8/direction', 'low')
io.writefile('/sys/class/gpio/gpio71/direction', 'high')
tty1 = '/dev/ttyACM3'
tty2 = '/dev/ttyUSB2'
for i = 1, 20 do
  os.sleep(1)
  if io.exists(tty1) then
    tty = tty1
    break
  elseif io.exists(tty2) then
    tty = tty2
    break
if not tty then
  log('init failed')
  return
buf = {}
function send(cmd, timeout)
  port:write(cmd .. '\r\n')
  local res, err = port:read(1000, timeout or 1)
  return res, err
function sendlog(cmd, timeout)
  local res = send(cmd, timeout)
  if res then
    buf[ #buf + 1 ] = res
port = require('serial').open(tty)
log('open port', tty)
for i = 1, 20 do
  res = send('AT')
  if res then
    break
if not res then
  log('no response')
  return
sendlog('AT&F', 10) -- reset settings
sendlog('ATE1') -- echo enabled
sendlog('AT+CGDCONT=1,"IP","' .. apn .. '"') -- set apn
sendlog('ATD' .. dial) -- connect
res = table.concat(buf)
log(res)
Init fails means that the modem cannot be detected. Most likely it is completely broken.
