Blurring icons in Visualization
Hi everybody,
I have a Modbus address with data type "07. 2 byte unsigned integer" to control the fan speed.
With value 1 the fan speed is at: low
With value 3 the fan speed is at: medium
With value 5 the fan speed is at: high
Do you have any idea how to highlight the icon when I select 1 control value and the other 2 icons will be blurred?
Thanks!
easiest way - you can load to controller your 3 icons (may be create one more when ventilator is stopped), and on visualization configuration page select additional icons, than add values and icon regarding value.. So when value = 1 you will see Icon 1, when value = 3 will see icon 2 etc..
Also you can find or create movable svg icons. I added 2 such icons to you. Find info in the internet how create your svg icon. I use free graphical soft Inkscape:
https://inkscape.org
Alex
.svg   fan-active2.svg (Size: 2.36 KB / Downloads: 16)
.svg   fan.svg (Size: 1.58 KB / Downloads: 12)
(25.08.2024, 17:43)AlexLV Wrote: Hi,
Alex
Thank you very much!
Best regards!
