Threads: 68
I've seen that topics beginning with $ are system topics.
Is it a restriction in the topic input box? Because I've tryed using Mqtt-Explorer and I can use $ in topics.
Check PM. Let me know if the new version works for you.
Threads: 67
Hello, I have a offline LM. Can I get install file for the MQTT Client APP?
Threads: 6
30.07.2025, 07:36
(This post was last modified: 30.07.2025, 07:38 by myg.)
I have a Zigbee bridge that sends MQTT topics from devices, which I process on LM. In one particular case, I want to connect two devices — a button and a relay — so that one can switch the other. I’ve created a mapping, and in the script for the button, I write to the group address (GA) that is mapped to the relay.
However, this action doesn’t work (i.e. triggering a mapping rule from within another mapping rule). I suspect this is to prevent processing loops.
Is there a way to make this work without creating a proxy GA for the button and using an event script to write to the relay GA?
Example config in MQTT Client:
zigbee/relay (on/off) -> 1/0/0 (bit)
zigbee/relay/set (on/off) <- 1/0/0 (bit)
zigbee/button (single/double) -> if (action=="single") then grp.write('1/0/0', true) end
Threads: 35
If they both Zigbee, why don't you link them in Zigbee? You could do it if you would use our Zigbee app.
Threads: 35
In this case use separate groups and link them via script. In general it is better to link everything locally (zigbee in your case) and just monitor/control from outside (MQTT- LM) Normally you just need to control the relays from LM.
Threads: 4
Sorry if this has already been asked, will the MQTT app work with Wiser?
Threads: 35
It should but SE is already painting our app green. No idea how long it will take them.
Threads: 68
Is it possible to connect to more than one broker from the same LM?
The app supports only one connection. For multiple connections you need to use scripts.
Threads: 54
I have this error while im trying to connect to mqtt broker , error: pre-connect failed - Operation timed out, code 14.
Threads: 35
Do you connect to a local or a cloud broker?
Threads: 35
Is it our LM broker installed on same device? If yes then use as IP 127.0.0.1
