MQTT Client app - Beta testing
#21
Check LM Error log. Are you using encrypted or plain connection?
(02.10.2024, 13:08)admin Wrote: Check LM Error log. Are you using encrypted or plain connection?
i sent PM with the parameters
Thanks, the problem is that your server does not support MQTT V5. It is required by the app to filter out unneeded messages. We can add a config option to allow older protocol versions to be used at your own risk Smile
