2 LM communication
I'm trying to connect 2 logic machines that are in different LANs. I have communication between them via routes in a ZeroTier network, but when I try to modify an object in both at once, it doesn’t work. Is there any way to make it possible? Thanks in advance.
See this: https://forum.logicmachine.net/showthrea...1#pid36221
If two LANs are connected you can enable multicast routing between them and increase TTL value in LM KNX settings according to the number of hops between these networks.
