Threads: 7
Then you should use a iframe (:
You can place it as an image, but then it might begin streaming even when plan is not visible.
Yes, but it will then be applied to all windows like other cameras or graphs. It's not a problem if that's the only window that you have.
Threads: 31
Ok, now I tried to use the image like you said and it works fine, It's a problem that it streaming all the time? Can do this a problem in a CPU usage? Thx
Threads: 7
The stream is direct to browser, LM does nothing with the stream so CPU load is only on client side.
