What would be the easiest way to make the Mosaic 'Switch' object be a similar size to the 'Dimmer Horizontal' object?
Ideally the Switch would be more flexible in size like Dimmer Horizontal object.
I have set the Dimmer Horizontal object to only be 1 height and would like the Switch object to match 3 wide and 1 high. Or at minimum 3 wide and 2 high (if it has to be 2 high).
I seem to get errors creating my own custom, export and import.
Sorry, discovered negative position values, as well as header features.
Wow this device is great !!
Could Mosaic be implemented on Schneider C-Bus module with requests?
How do you add an Icon to a custom button?
I would like to add one of the standard icons to it, instead of a text button.
Thank you
Thank you
