IrrigationCaddy integration module
<- EDIT: updated version, download it again and look at last post for changes. ->
here is a module for interacting with IrrigationCaddy controller.
As usual you can find module and example attached.
I use two event based script. I trigger them for updating status or updating configuration use a KNX group.
The script for updating the status is:
old_print = print
debug_level = 0
print = function(...)
 if ( verbose ) then
   log(...)
irrigationcaddy = require("user.IrrigationCaddy")
syslog_level = ERR
verbose = false
irrigationcaddy.ip = "192.168.1.100"
irrigationcaddy.update()
print ( string.format ( "IC status %s", irrigationcaddy.allowRun ) )
ic = grp.getvalue ( '0/1/40' )
ic_status = grp.getvalue ( '0/1/41' )
if ( ic_status ~= irrigationcaddy.allowRun ) then
print ( string.format ( "IC status (%s) different from device (%s)", tostring(ic_status), tostring(irrigationcaddy.allowRun) ) )
grp.write ( '0/1/41', irrigationcaddy.allowRun, dt.boolean )
The script for updating the configuration is:
debug_level = 5
verbose = true
irrigationcaddy.ip = "192.168.168.73"
print ( string.format ( 'Evento da %s per %s tipo %s', event['src'], event['dst'], event['type']) )
group = event['dst']
if ( group == '0/1/40' ) then
    if ( ic_status ~= ic ) then
   print ( string.format ( "Changing IC status (%s)  to %s", tostring(ic_status), tostring(ic) ) )
   if ( ic == false ) then
     irrigationcaddy.disable()
   elseif ( ic == true ) then
     irrigationcaddy.enable()
   grp.write( '0/1/49', true, dt.boolean )
Finally the script that triggers the update is:
log ( 'Triggering IC update' )
grp.write('0/1/49', true, dt.boolean )
return
Where group 0/1/49 is the triggering group.
I've chosen this approach to trigger update on configuration and on scheduled base.
Luca
.lua   irrigationcaddy.lua (Size: 11.93 KB / Downloads: 10)
.lua   testirrigationcaddy.lua (Size: 805 bytes / Downloads: 5)
Dear Luca,
I am purchasing the ICEthS1 irrigation caddy products.
I read your scripts but I have not seen about reading, for example, the group address related to status of a valve.
What do you think about that?
Hi there,
reading the script on the "gateway example" of the web site, it seems that we can verify on HL the status of irrigation system.
But I cannot identify in which part of the script we can command manually a zones. Is it possible in your opinion?
(06.05.2017, 07:52)Domoticatorino Wrote: Hi there,
Hi, please have a look at example file. You have status' variables in object that can assign in you script.
Actully the module doesn't handle programs and zones start/stop. But it shouldn't diffifcult to add.
Luca
I've just uploded latest version.
It adds support for starting and stopping programs, including "run now" with single zones' timers.
Luca
