Mosaic status
hello, im having hardtime finding a solution for my problem and i need you helpĀ
when i connect the status on/off of a light in mosaic the status turn off and i cant turn off the light unless i turn it on first.
Has this happened to anyone?
You should investigate why your status value is not correct. You can add periodic pool interval on the object.
this happend at the objects that i added to today the others work fine
