Shelly 3em- MQTT
Hello guys ,
I have made integration with a shelly 3em over mqtt, in the mqtt explorer there is not appear the total consumption . is there any way i can make a scrit to add L1  consumption-  L2  consumption - L3 consumption so i can take the total  consumption
Thank you in advance!
See this: https://forum.logicmachine.net/showthrea...6#pid14506
(13.01.2025, 12:56)admin Wrote: See this: https://forum.logicmachine.net/showthrea...6#pid14506
Thank you!!!
Thank you!!!
i tried it but the number i get it realy big is any way to display smaller number i tried this code but it returns 0
local offset = event.getvalue() * 0.001
if event.getvalue()
  then grp.write(event.dst,offset)
thank you in advance!
In general grp.write(event.dst, value) should not be used in event scripts. You are creating an infinite loop where each write triggers the script again.
If you want to scale the resulting value simply modify the tag_sum script. You won't need an additional script this way.
grp.checkwrite('1/1/1', sum * 0.001)
