I hope you are well.
We are facing an issue with status height in shutter vertical widget in Mosaic3.0.
Altghough the icon of the slats works properly, the slider doesn't respond to the correct position.
(23.01.2025, 08:33)Daniel Wrote: Can you share some screenshots what you have in mind exactly?
The icon in the black circle (the lines-slats) changes based on the status (when the roller is up, appears one line-slat and when it is down, appears more lines-slats).
But the position of the circle-slider does not change.
When a user moves a roller with the buttons up/down in the widget (and not via the slider-height), then the icon inside updates its value showing more or less lines, but the position of the slider-circle remains in the same position.
Only if you close-refresh the app or change room and enter again, the slider appears the right position.
