Lm rebooting after mosaic change
hello guys i have  a new problem with my lm each time i try save a change at  widget in mosaic the lm rebot .
does that happend to anyone before
Do you use custom images?
(27.01.2025, 10:08)Daniel Wrote: Do you use custom images?
i have general custom image backround and custom icons on some widget
This is your problem, Mosaic has a design issue and it is limited to few MBs of custom images.  The limit is around 8-9MB but each time you use even same custom image it is still counted as new and added to the total. Run this script once, it will move all custom images to LM images and replace yours with url.  The issue with such solution is that you will not see images from cloud.  This will fix your project and if you still want to use custome images also in cloud then make the size as small as possible.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263
require('json') require('encdec') mosaickey = 'mosaic30:config:0' config = storage.exec('get', mosaickey) -- config = io.readfile('mosaic-backup.json') config = json.pdecode(config) icons = {} relpath = '../../../../scada/resources/icons/' abspath = '/www/scada/resources/icons/' function fixicon(tbl)   local file = tbl.file   if type(file) ~= 'string' then     return   end   if file:sub(1, 10) ~= 'data:image' then     return true   end   local hash = encdec.md5(file)   if not icons[ hash ] then     local poss = file:find('/')     local pose = file:find(';')     local posd = file:find(',')     local ext = file:sub(poss + 1, pose - 1)     local filename = hash .. '.' .. ext     local data = encdec.base64dec(file:sub(posd + 1))     io.writefile(abspath .. filename, data)     icons[ hash ] = relpath .. filename   end   tbl.file = icons[ hash ]   return true end function fixstruct(tbl)   for key, val in pairs(tbl) do     if type(val) == 'table' then       if not fixicon(val) then         fixstruct(val)       end     end   end end fixstruct(config.floors) fixstruct(config.imported_widgets) config.custom_icons = icons config = json.encode(config) storage.exec('set', mosaickey, config)
(27.01.2025, 10:19)Daniel Wrote: This is your problem, Mosaic has a design issue and it is limited to few MBs of custom images.  The limit is around 8-9MB but each time you use even same custom image it is still counted as new and added to the total. Run this script once, it will move all custom images to LM images and replace yours with url.  The issue with such solution is that you will not see images from cloud.  This will fix your project and if you still want to use custome images also in cloud then make the size as small as possible.
is there any way at least to the cloud to be viseble the deafult icons ??
Default icons will stay, only custom icons.
(30.01.2025, 13:59)Daniel Wrote: Default icons will stay, only custom icons.
sorry i dint explain well, i meant to display  the defualt icons to the widgets that i have custom icons
I'm not sure if I fully understand you. A widget/element can have one icon. It cannot be one locally and another in cloud.
(30.01.2025, 14:41)Daniel Wrote: I'm not sure if I fully understand you. A widget/element can have one icon. It cannot be one locally and another in cloud.
You understund well... thank you very much
