Threads: 42
Will the option to import or export custom widgets be implemented?
Threads: 35
Plans/layouts/widgets will have import/export feature.
Threads: 42
16.01.2026, 08:17
(This post was last modified: 16.01.2026, 08:19 by davidchispas.)
Hello. I'm not sure if this has already been discussed here.
1. In the Mosaic version, there's an option to add a category bar. Since I usually customize it, and for faster processing, could you add the ability to duplicate an existing bar, like with any other widget?
2. Regarding widgets, I'm missing a combination of a slider widget and a 1-bit motion widget to control the blinds. The circular or vertical slider allows you to add minimum/maximum buttons, but it's missing a stop button. It would be great to add and be able to select that option.
Threads: 42
28.01.2026, 13:57
(This post was last modified: 28.01.2026, 13:58 by davidchispas.)
Could the inverted object option be integrated into the on/off control widgets? The previous tile included this option.
Threads: 35
What do you mean by 'power control widgets' ?
You can fully customize how ON and OFF states look. Are you sure that inverse option is really needed?
Threads: 0
Hello there. Do we have any widgets for shutter control in Visu? I don't see any. I have a LM4 which i updated with the last available firmware. Thank you.
stavros
Threads: 35
Movment 1bit, otherwise you can use sliders.
Threads: 32
28.03.2026, 21:22
(This post was last modified: 29.03.2026, 05:42 by KoBra.)
Airconditioner Widget as they don’t use the 20 hvac dpt
@davidchispas, Invert option for Toggle widget will be added in the next version.
@KoBra, can you describe what features are needed in the AC widget apart from setpoint control and current temperature display?
