Alert manager ipk
Good morning Dev,
Could be possible have the ipk file for app in object? I have a client without internet connection.
Could be interesting open a section with all this file. Now a day happens often LM not connected to web.
Best regards Cristian
https://forum.logicmachine.net/showthrea...3#pid22783
Hello Dears,
I want to use the app acknowledge to trigger a GA, to be used for a KNX Touch screen acknowledgement
Best Regards,
This is not possible in Alert app.
Only possible when the app is embedded via iframe into your visu, here is a sample custom JS that makes some interaction possible:
$(function() {     // Remote Press Acknowledge Button     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             if (typeof grp != 'undefined') {                 grp.listen('0/3/0', function(object, state) {                     if (state == 'value' && object.value == true) {                         f.contents().find('#AcknowledgeButton').click();                     }                 }, true);             }         });     });     // Remote Press Mute Button     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             if (typeof grp != 'undefined') {                 grp.listen('0/3/1', function(object, state) {                     if (state == 'value' && object.value == true) {                         f.contents().find('#MuteButton').click();                     }                 }, true);             }         });     });     // Write to object when Acknowledge is pressed by a user     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             f.contents().find('#AcknowledgeButton').click(function() {                 grp.write('0/2/0', false)             });         });     });     // Write to object when Mute is pressed by a user     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             f.contents().find('#MuteButton').click(function() {                 grp.write('0/2/0', true)             });         });     });     // Hide Acknowledge Button     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             f.contents().find('#AcknowledgeButton').hide();         });     });     // Hide Mute Button     $(document).ready(function() {         var f = $('iframe');         f.load(function() {             f.contents().find('#MuteButton').hide();         });     }); });
Many thanks @Erwin
This is exactly what I need
Best Regards,
