Threads: 34
Could I obtain the CSS file associated with the Mosaic presets?
Furthermore, would it be possible to import the modified file after updating it?
Or is there an easier way to make a preset?
Threads: 31
Such modifications will be available only locally. What is the widget name do you refer too?
Threads: 31
In this case, just go to Settings & themes, modify as needed and export your settings. You can then import it to any of your projects.
Threads: 34
okay, thank you, I just hoped there were a css file where I could change fonts, buttons(widgets) etc
