17.04.2025, 10:50
Hello. I use Wiser for KNX (LSS100100) and Wiser KNX app on iPhone. When i try to connect to Wiser for KNX thought Wiser KNX app i have a warning "Something went wrong while initializing the appication. The controller seems to be offline." and there is also the ability to choose further action "Try again", "Ignore" or "Logout". The connection will not be successfully whatever i choose. This has been going on for a day already. The result is the same when I try to make connection through another iPhone. The internet connection is ok. Moreover I can connect to Wiser for KNX (LSS100100) using WEB interface and i see that it works normally and i can operate it. Of course i can restart the device and everything can be normal again, but in this case i will not actually know what was the problem and it can happen again.
