Alert Manager
#41
Only with pushover..
(24.09.2018, 16:36)domotiqa Wrote: Great job !!
is there a way to have IOS push notification.
Only with pushover... ?
https://forum.logicmachine.net/showthrea...19#pid6419
I guess the cloud is only for LM device, not for SL and HL
SE ECO EXPERT
(26.09.2018, 07:25)domotiqa Wrote: I guess the cloud is only for LM device, not for SL and HL
Correct
Hey Erwin,
Is there any way to change the color settings of the alert app?
Bij Custom CSS?
Dennis
No, none of the apps can be changed by custom css.
(07.06.2017, 18:09)Erwin van der Zwart Wrote: Hi,
You can put the alert manager into a iframe (use as URL: /apps/data/alerts ) inside your normal visu and when you do that, the back button is automaticly hidden. When you check the persist checkbox on the iframe settings the app will be opened automaticly when there is a new alert.
Inside the menu of the alert manager app you can disable the pagejump on new alerts. Audio will always be started or you can mute it for always in the app menu.
I trie create a iframe with URL: /apps/data/alerts/
When I access internally everything works fine. But when I access by cloud I have the error:
Not Found (#404)
Page not found.
The above error occurred while the Web server was processing your request.
Please contact us if you think this is a server error. Thank you.
Best regards,
I had a problem.
I created the backup on my test server.
Then go to customer building (no internet). I could'nt download AlertManager on the HL... the module is not in the backup !
SE ECO EXPERT
Install it via file
https://we.tl/b-yInxytfwsP
(17.07.2019, 07:46)Daniel. Wrote: Install it via file
thank you
SE ECO EXPERT
Simple question on the alert() function.
Is there otion inside like alert( msg , option)
I try to log in the alert manager event from Alarm system activation/desactivation (without sound and maybe different color because not very important).
And for more important alarm, keeping the sound
regards
SE ECO EXPERT
No, the command alert is only adding a entry in the alert tab, and that's all the LUA script does.
The alert manager receives the content of this alert tab including timestamps over a websocket (and has a polling fallback when the websocket is disconnected), and whenever there is a timestamp that is newer then the last acknowledged timestamp (that is stored in the storage after acknowledge) the audio is started. There is no option to set additional parameters by default.
Hello Daniel,
I hope you are well, is it possible that you will upload the alert manager app file again? I tried but it was already deleted.
Regards.
https://we.tl/t-wVuBeKVImf
Hello Daniel,
Is it possible that you will upload the alert manager app file again? I tried but it was already too late))
Regards)))
You can download it direct in your controller from the appstore, no file needed (:
https://we.tl/t-do1rpF066y
(25.02.2020, 18:07)Erwin van der Zwart Wrote: Hi,
Yes, now I can see))) Thank you.
P.S. I had before wrong settings and wiser didn't have Internet access
Normally, yes. But the problem is that in many cases the LM/SL is installed in closed technical network, and the LM/SL have no Internet access. It would therefore be good to have the possibility to download the different apps from somewhere.
How do I get rid of the popup when creating the alarm???
