Threads: 21
I have a new client who has 25 rooms installed with KNX. The problem is that the old integrator had created the program only for one room and simply had an IP router in each room and simply selected the interface to program the room. Is there any way to create the visualization without having to rebuild the project from scratch?
Thank you in advance !
Threads: 8
05.06.2025, 04:03
(This post was last modified: 05.06.2025, 04:08 by Erwin van der Zwart.)
I guess all 25 “mini projects” are just a duplicate and i assume every room uses the same group addresses? If that is the case than you need to redo everything to bring it together on KNX side or you need a controller in each separate room..
There are tools (ets apps) that could help you to do this, i believe it’s called something like extended copy from KNX Org itself, there you can duplicate devices and set an offset in the addresses
