Pop UP Custom Value Height
How can i adjust the size (Height) of a popup box. I have 7 custom values, but the pop up only show 5 of them, so you have to use the slider to show the missing 2 values.
I there a way to show all 7 custom values so the user does need to use the slider ?
Also need to enlarge the popup and center all popups to the center of the screen
(07.06.2025, 15:27)sjfp Wrote: How can i adjust the size (Height) of a popup box. I have 7 custom values, but the pop up only show 5 of them, so you have to use the slider to show the missing 2 values.
Sorted, used the following in CSS
.control-vselect .popover-content .nav {
  max-height: 250px;
  overflow-y: auto;
Use this CSS to center the control and make it larger:
.control-vselect {
  top: 50% !important;
  left: 50% !important;
  transform: scale(150%) translate(-50%, -50%) !important;
.control-vselect ul {
  max-height: none;
Thank you for your help. Appreciated
