Threads: 22
I have a client who has a Homelynk on their installation running with LM5 firmware.
Everything works perfectly except the RS232 port which is not recognized.
Do you have a solution for this?"
Jean-Marc
Threads: 30
How did you test it?
Threads: 30
Actually this is correct. Hw is not the same as LM and this will not work.
Threads: 22
Yes of course I just copied the function but require('serial') is present in the script
Jean-Marc
Threads: 22
hi,
When Hw runs with its own firmware, the RS232, ModBus, and USB ports are fully usable.
When Hw runs with the LM5 firmware, only the RS232 port is no longer usable.
So, it's just a software issue and not a hardware one. Do you have a solution?
Jean-Marc
Threads: 30
No
