Zwave APp
Hello yesterday I did a factory reset and now the zwave app doesn't appear.
I know it's no longer supported,
But it works perfectly for me with several plugs I have.
please, if you could post the different versions in a repository (because I don't think I updated to the latest one), so that we can install it, of course under our responsibility I would be infinitely grateful, as I can't use the outlets right now. Angel
Thank you very much in advance.
Best Regards.
Jose
Try this:
https://dl.openrb.com/pkg/zwaveapp-imx6-20200702-2.ipk
Thank you very much for your quick response.
But I tried adding a device that previously worked without problems, and the LM just freezes.
The APK I had installed was probably from 2019, which is when I bought the devices.
I have tried to install the previous backup that I had installed in LM, to see the zwave version, but I have discovered that the apps are not backed up.
If there's another version, I'd appreciate it.
Thank you again in advance.
Best regards.
Today I tried to load the ipk suggested for the new cpu version on my LM HW: LM5 Lite (i.MX6) SW: 20240426 but do not run, or best,  run but the left menu is void.
Did you have a solution?
Try this patched version: https://dl.openrb.com/pkg/zwaveapp-imx6-20200702-2.ipk
It should now work correctly when starting the Z-Wave daemon from the web UI.
