2 LM different networks
What is the best way to get GA communication from 1 network 2 another?
If we setup 1 LM as modbus RTU slave (Green connection) that will work, but is there a better method?
What will happen if we connect KNX between 2 LM´s (Red connection)?
Or is there a better solution?
[Image: m340qKI.png]
I would suggest MQTT, see this app
https://forum.logicmachine.net/showthread.php?tid=5878
You will need broker on one of the LMs.
