Yesterday, 16:14
Hello!
I have bought the Zigbee RS232 GW and a few Namron electric thermostats for a specific project. The thermostats are Namron Zigbee Touch Thermostat 4512752.
I checked the the Zigbee Compatibility list and found that Namron Touch Thermostat 4512737 was compatible, but it seems like that particular thermostat is no longer in production (not as i could find, so i hoped the 4512752 would work).
I get this as device info:
Manufacturer: _TZE204_p3lqqy2r
Model: TS0601
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Groups (4)
- Scenes (5)
- 61184
Output clusters
- Ota (25)
- Time (10)
When I monitor it reports "empty" messages when i change setpoints (see attached screenshot).
I have a resident script that tries to read from the normal attributes of the device:
But its timing out (see errors in attached screenshot).
Am I correct in assuming that this device is not supported?
Model: TS0601
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Groups (4)
- Scenes (5)
- 61184
Output clusters
- Ota (25)
- Time (10)
-- Set the polling interval in seconds (e.g., 60)
local poll_interval = 60
-- Initialize lastpoll timestamp if it doesn't exist
if not lastpoll then
lastpoll = 0
-- Check if it's time to poll again
if os.time() >= lastpoll + poll_interval then
-- It's time, so update the timestamp immediately
lastpoll = os.time()
-- Load Zigbee library
local zb = require('applibs.zigbee')
-- Device info
local mac = '3425b4fffecf73b8'
local endpoint = 1
local cluster = 0 -- Basic Cluster
log('--- Polling Thermostat ---')
-- 1. Read the Measured Temperature (Attribute 65506)
local temp, err_temp = zb.cmdsync('getrawattribute', mac, endpoint, cluster, 65506)
if temp then
-- To write this value to Group Object '1/1/1', uncomment the next line
-- grp.write('1/1/1', temp)
log('Thermostat Measured Temperature: ' .. tostring(temp))
log('Failed to read temperature. Error: ' .. tostring(err_temp))
-- 2. Read the Heating State (Attribute 65508)
local state, err_state = zb.cmdsync('getrawattribute', mac, endpoint, cluster, 65508)
if state then
-- To write this value to Group Object '1/1/2', uncomment the next line
-- grp.write('1/1/2', state)
log('Thermostat Heating State: ' .. tostring(state))
log('Failed to read heating state. Error: ' .. tostring(err_state))
