Threads: 106
Can you explain active color and Inactive color in Appearance Setting ? I couldn't find a change in both tile and plan view.
Threads: 35
This is related to everything which has two states like push button ON/OFF. Active state is ON whee inactive Off.
Threads: 106
I added a switch widget. There are ON and OFF State. I can change color and background of both ON and OFF state. What is the difference between active color and Inactive color in Appearance Setting and ON and OFF State's color and background ?
I changed active color and Inactive color in Appearance Setting and i can't see a difference.
Threads: 35
For a switch only Global settings works, we will probably remove it from local as you can set it in Settings.
