Multistate knob widget
Good day,
is it possible to make a multistate knob widget with the old visu? I would like to add it to an old project.
something like that:
Thank you
Use Additional icons, you will need images of the knob in different states.
It's possible to create a multi-state button using send fixed value attached to a virtual object. Set the multi-state object as status. Use additional icons to set an icon for each state.
Map an event script to the virtual object. Each write to a virtual object will change multi-state value to the next one (0, 1 or 2).
out = '0/3/3' val = grp.getvalue(out) val = (val + 1) % 3 grp.write(out, val)
Great, thanks!
