19.02.2017, 09:02
For reasons unknown, a number of object were updated with dates in the future (18.02.2034). After that these objects were not updated anymore.
I tried to solve this by restoring from an older backup but that didn't solve the problem.
I then manually updated these objects with the values they had but now with the correct date. After that everything seems to be back in working order.
A number of these objects had logging on since they are used in graphs.
Before I corrected the objects, the graphs extended to 2034 which made them rather useless... After my manual correction, the graphs look almost normal again, but one can see that there is some value in the future. See attached image.
I would like to get rid of this, but simply disabling the logging and re-enabling it afterwards does not help. I also cleared the objects log.
So, is there a way to clear the existing data set for these objects?
