Threads: 149
Good morning,
I'm just starting to use the new view. There's a way to lock objects in the editing mode so they don't move. Thank you very much.
Threads: 30
There is no such thing like lock object in Admin view. You can play with Layouts and if you put object on layout and attach it to a plan then you will not be able to move it while on plan but you will see it(little bit faded)
Threads: 30
Sorry only one layout per plan
When selecting widgets via mouse click you can hold ctrl or shift to add or remove widgets from the selection.
