Weather app
New Weather app for testing.
It is very simple, just define coordinates and select or create new objects. Values can be updated instantly by pressing the Save and update weather button. The weather will be updated once every hour. Objects are updated on change of value.
.ipk   weather-20260217.ipk (Size: 179.39 KB / Downloads: 86)
Hi Daniel,
Very interesting and useful app!
How often info renew from the weather portal? May be for next app version is possible to add group from/to for automatic assigning weather info for new projects for faster integration? And finally we need weather widget for new visu!
Big thanks for your work!
Alex
Hi Daniel,
good work as always, do you think it is possible have a string object with the condictions? For example Sunny, cloudy, rain or other
Best regards Cristian Grassi
The app is nice, thank you. As far as I can see it's more or less functionally equal to the script at https://kb.logicmachine.net/scripting/yr...-forecast/ (which is also nice)
But met.no have all their icons also available for download: https://nrkno.github.io/yr-weather-symbols/
What would be the easiest/best way to implement those in Visu..? There are so many...
Condition code text will be added in the next app version.
Weather widget is planned for later, the list of possible conditions will be simplified.
does it rum on Old CPU ?
It should work on old CPU devices.
We don't generate any new content for imx28 as it is not supported, if it work use it if don't use script version.
