LM4 (i.MX28) SW: 20240426 lagging
Recently updated LM4 to SQ20240426 and the system became noticeably laggy and almost UNUSABLE.
KNX event-based scripts execute with several seconds delay.
Version: 20240426
CPU/IO: 0.28 0.45 0.64
Memory: 35%
KNX/TP: OK
CPU sometimes peaks to 1.5 without visible load.
There are 2 Modbus devices configured.
Polling was 10s, now increased to 45s, but lag still present.
Stopping several Lua scripts did not change behaviour.
Previous firmware worked perfectly on the same hardware.
Is there any known issue with KNX stack, scheduler or IO handling in SQ20240426?
Any ideas what to do?
thanks!
Noone never reported anything. SD probably giving sign of death.
Install System load app and see which process is consuming system resources. You've asked about HA integration, is it the same LM? Maybe the problem is connected.
(24.02.2026, 13:33)admin Wrote: Install System load app and see which process is consuming system resources. You've asked about HA integration, is it the same LM? Maybe the problem is connected.
HA is a separate machine only for visuals. What changed - I've added dozen of DSTs to groupread function thru a tag.
System monitor shows highest ~20% at peak:
/usr/bin/eibd-e 1.1.201 -q 100 -L 1 -Q 0 -E xx.xx.xx.xx -T -f eth0 -D -R -S224.0.23.12 -F n,n,n,n,0,0 tpuarts:/dev/ttyAPP4
resident lua - ~3% each at maximum.
Thank you!
You can use Group monitor app to see the sent telegrams and if there are any repeats.
Thank you, I will check.
Is it possible to understand what script is exactly by a script number here:
942 resident 7lua/lib/genohm-scada/core/scripting-resident.lua 7 3.69% 3.89MB
940 resident 5lua/lib/genohm-scada/core/scripting-resident.lua 5
5 and 7 are script ids, editor URL is http://LM_IP/scada-main/main/editor?id=5
